주요 콘텐츠로 건너뛰기
2015년 9월 25일 출시. Model A1687/A1634. 수리는 이전 모델과 유사하며 스크류 드라이버 및 비집는 도구가 필요합니다. GSM 또는 CDMA / 6, 64, 또는 128GB / 은색, 금색, 스페이스 그레이 및 로즈 골드로 제공하였습니다.
1041 질문 전체 보기
2 completely dead iPhone 6s plus devices
I obtained 2 completely dead iPhone 6s plus devices. They do not charge or are recognized by iTunes (with or without battery connected to the motherboard). They do not warm up. I currently do not have an ammeter, but I used a battery pack that automatically detects devices. These are not detected. I suspect that both devices have a bad U2 IC, but I'm not sure of that. I already ordered a new battery and dock connector. But these are still on their way. I ordered these just to be sure.
Will the device boot with a new charged battery if the U2 IC (normally only for charging and USB connectivity) is dead? Or are there any more steps I can perform?
Thanks in advance.
Kind regards, Stefan
이 질문에 답하기 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 0
댓글 달기
답변 1개
가장 유용한 답변
iPhones do bootup with charged batteries that have a bad Tristar (U2) charging IC.
Some things to note:
If you can't get an apple logo with battery unplugged the Tristar is bad provided you can turn the phone on with a charged battery.
Once you get the phone on you can also try plugging the phone to a computer to see if it detects via iTunes / 3Utools.
해당 답변은 도움이 되었습니까?
점수 4
댓글 9개:
Hi Ben,
Thank you for your valuable information. I will test it as soon as I have my new battery.
I will report the result then.
If it is indeed a Tristar problem, perhaps I'm going to give it a try to do it myself. I can solder but have no experience in micro-soldering, but at least I can give it a try.
Your information is very much appreciated.
Kind regards,
Stefan
You will need a hot air station to replace Tristar, if you have soldering iron only you cant replace it as the solder balls are under the chip.
Hi Ben, I will order a hot air station as it comes always in handy. It's going to be quite a challenge because I never did such a thing. I will order the Tristar as well. I will probably need it anyway so :) Thanks again for your help ;) Kind regards, Stefan
Here is some good information on replacing the tristar chip:
iPhone 6S Tristar IC Replacement Tips
Hi Ben, Thank you very much. It's a really good starting point. I will exercise first a bit on another device to see if I succeed in removing the components without pulling the pads beneath the chip.
댓글 4개 더보기
댓글 달기
귀하의 답변을 추가하세요
Stefan 님은 대단히 고마워 할 것입니다.
조회 통계:
24 시간 전: 1
7일 전: 1
30일 전: 1
전체 시간: 1,109
