주요 콘텐츠로 건너뛰기
2017년 3 월에 출시된 G6은 Android 7.0 기반 LG의 주력 핸드폰입니다. 이 기기는 모든 주요 무선 통신사에서 사용할 수 있습니다. 이 기기를 물리적으로 수리하면 방수 기능이 사라져 물에 취약할 수 있습니다.
How to tell if motherboard has been damaged from a fall?
Dropped it from about 3 ft onto cement, glass is cracked and screen will only display one single vertical line from top to bottom. My question is there a way to tell if just the LCD and digitizer needs to be replaced or is something on the motherboard messed up too? I think I'm handy enough to attempt a screen repair but don't want to burn 100$ on a futile repair. Vibrator motor seems to respond to power button inputs and it does make a sound when power button is held like to power on or off. Thanks for your input.
답변되었습니다! 답변 보기 저도 같은 문제가 있습니다
좋은 질문입니까?
점수 0
댓글 달기
답변 1개
선택된 해법
Hi @dddy ,
The only way to initially tell if there may be a problem is to open the phone and to closely inspect it (use a magnifying glass if necessary) for any obvious physical or possible electrical damage that could have been caused by the fall, e.g. cracked pcb, loose components or cable connections, or “distressed” (burnt looking) components caused by non catered for circuit paths created by the fall.
If everything appears to be OK then a screen replacement (even temporary) is the only way to find out what is really happening with the phone.
Here’s a link to the ifixit LG G6 guide, which may be of some help.
이 답변이 도움이 되었나요?
점수 3
댓글 1개:
Thank you, very helpful information
댓글 달기
답변을 추가하세요
Tom Pengelley 영원히 감사할 것입니다.
조회 통계:
지난 24시간: 0
지난 7일: 0
지난 30일: 1
전체 시간: 227
