주요 콘텐츠로 건너뛰기
6s와 유사한 하드웨어 사양의 4-inch iPhone은 2016년 3월에 출시되었습니다. 16/64GB 저장 옵션 및 은색, 스페이스 그레이, 금색 또는 로즈 골드로 제공됩니다. 모델 A1662 및 A1723.
1049 질문 전체 보기
replacement display has touch digitizer issues only when out of casing
I got an iPhone SE LCD Screen and Digitizer Full Assembly from iFixit, and
I have replaced the display on my iPhone SE, and the display looks nice, but the touch digitizer is pretty unusable. Tapping is not reliable (typing is almost impossible), and gestures such as swipe or pinch to zoom are very difficult too.
I have done a hard reset (a DFU Restore), just to be sure it wasn't a software or firmware issue, and then I've taken the part off and re-seated the connections a few times, but it hasn't solved the issue. Interestingly, if I reconnect everything (LCD, camera and sensor, and digitizer, and also Touch ID connector), and turn the phone on before I put the display back into the phone casing, then the touch screen works pretty much perfectly. As soon as I set it snugly into its casing where it belongs however, the issue comes back. This is a repeated observation, and I'm reasonably confident now that the issue comes from something touching something when it's fully put together making an electrical connection / grounding that shouldn't be being made.
Here is a video of the behavior I'm describing.
I would insulate something, if I knew what to insulate. Does anybody know?
Update (06/06/2018)
As @aonemob suggested, I insulated those flex cables (with electrical tape).
BEFORE:
AFTER:
It did improve the responsiveness of the screen, but it still is not perfect, in comparison with a genuine apple touch screen I compared with on another phone. Perhaps the replacement part is just not as high quality.
답변되었습니다! 답변 보기 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 0
댓글 달기
답변 1개
선택된 답변
Hi @postylem, you are on the money.
The issue is caused by a lack of insulation, or a fracture, on the front most part of the flexes. Its commonly caused during the refurbishing process. You can try insulating the area as seen in the photo here, but if that fails, your best bet is to process a warranty claim on the screen in question.
If insulating does help, it was likely rubbing against the metal frame of the device upon assembly
해당 답변은 도움이 되었습니까?
점수 4
댓글 1개:
Thank you! I did this, and it did seem to work a bit, though not perfectly. I can't post images in this comment, so I'm adding images of what I did to an answer below.
댓글 달기
귀하의 답변을 추가하세요
Joos Lieu Voorbach 님은 대단히 고마워 할 것입니다.
조회 통계:
24 시간 전: 0
7일 전: 0
30일 전: 0
전체 시간: 122
