주요 콘텐츠로 건너뛰기
Apple iPhone 5s는 2013년 9월 10일에 발표되었습니다. 수리는 이전 모델과 유사하며 스크류 드라이버 및 비집는 도구가 필요합니다. GSM 또는 CDMA / 16, 32, 또는 64GB / 은색, 금색 및 스페이스 그레이.
3530 질문 전체 보기
What is the problem occurring in my phone I dont know how to solve it?
It switch off during working.!! And when i am switch on it shows apple logo for 5 to 10 seconds and then showing blank screen and then switch offs again..!! I restart it and updated software and dfu mode.!! But it is showing again and again..after restarting it works properly for 1 or 2 days but after that tha problem occuring again and again..!! What should i do..!! Pls answer
답변되었습니다! 답변 보기 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 0
댓글 달기
답변 1개
선택된 답변
If it weren't the fact that it does appear to work for a day or so, once in a while, I would suspect the battery as being at the end of it's life. Still, to be certain, use a battery utility, such as coconutBattery (for Mac) or 3uTools (for Windows). It will tell you what the health of the battery is. Anything less than 70% of design capacity will require replacement.
If the battery is fine, then you likely have a logic board issue. Has anything happened to your phone recently such as a hard drop, a repair or contact with water?
해당 답변은 도움이 되었습니까?
점수 2
댓글 2개:
Bro how to check battery life of my phone?? Can u explain the process??
Download one of the applications I recommended, install it and connect your phone so that it can give you the design capacity.
댓글 달기
귀하의 답변을 추가하세요
Vinay 님은 대단히 고마워 할 것입니다.
조회 통계:
24 시간 전: 0
7일 전: 1
30일 전: 1
전체 시간: 56
