주요 콘텐츠로 건너뛰기
2012년 부터 13" Retina Display가 장착된 MacBook Pro 모델이 제작되었습니다.
4684 질문 전체 보기
Wi-Fi icon won´t show up
I have a MacBook Pro A1502, the wifi icon dosen´t show up, I´ve changed the wifi card and still the same. the Bluetooth is also damage. When I change the card for another one the bluetooth appear, but the Wi-Fi still disable, I can´t start nor create the service throught the terminal, it says that there is no Wi-Fi device. HELP PLEASE!!!
I also try to enable the wifi network service in the terminal but the listallnetworkservices command doesn´t show any wifi interface
답변되었습니다! 답변 보기 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 0
댓글 1개
The A1502 covers quite a few different models! Can you pick yours from this listing: A1502 systems
댓글 달기
답변 1개
선택된 답변
I’m suspecting the I/O cable needs to be replaced. Here’s the IFIXIT guide for the 2014 model: MacBook Pro 13" Retina Display Mid 2014 I/O Board Replacement and here’s the needed part: MacBook Pro 13" Retina (Late 2013-Early 2015) I/O Board Data Cable but without knowing your exact system I’m just guessing here.
MacBook Pro 13" Retina (Late 2013-Early 2015) I/O Board Data Cable 이미지
상품
$9.99
해당 답변은 도움이 되었습니까?
점수 1
댓글 달기
귀하의 답변을 추가하세요
Luis Anniel 님은 대단히 고마워 할 것입니다.
조회 통계:
24 시간 전: 1
7일 전: 3
30일 전: 3
전체 시간: 140
