주요 콘텐츠로 건너뛰기
MDR-ZX100 ZX Series stereo headphones made by Sony.
18 질문 전체 보기
wires are intact and look perfectly fine but I still have no sound
I'm having the same issue. My wires are intact and look perfectly fine but I still have no sound. I'm new to the blog. I came across the blog because I put my Sony speakers out and there was nothing really wrong with him it's just the right earpiece went out
이 질문에 답하기 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 0
댓글 달기
답변 1개
가장 유용한 답변
@watkinsm it is either the plug or the connection on the driver (speaker). To test it use a multimeter and place it on ohm reading. Touch the contact, either tip or ring, with one probe and the other probe on the driver. If you have continuity it is the driver if you do not, then it is the plug. Of course, check to make sure the wires are connected on your driver. Use this guide to get to the driver. Here is a guide that shows how to replace the plug. Different headphones, same principle. Hope this helps, good luck.
Skullcandy Lowrider 이미지
안내서
How to Replace the Audio Jack
난이도:
Moderate
30 minutes - 1 hour
Sony MDR-ZX100 이미지
안내서
How to repair Sony MDR-ZX100
난이도:
Moderate
15 - 30 minutes
해당 답변은 도움이 되었습니까?
점수 2
댓글 달기
귀하의 답변을 추가하세요
watkinsm 님은 대단히 고마워 할 것입니다.
조회 통계:
24 시간 전: 0
7일 전: 0
30일 전: 1
전체 시간: 44
