주요 콘텐츠로 건너뛰기
6MB 공유 L3 캐시 2.2 GHz (Turbo Boost 최대 3.4 GHz), 2.5 GHz (Turbo Boost 최대 3.7GHz) 쿼드-코어 Intel Core i7 프로세서.
773 질문 전체 보기
Black screen is seen with flashlight and works with external display
Hello good morning, I just turned on my Macbook pro 15" 2015 model: A1398.
I was reneging for a while until I could see with a flashlight the log in screen, logged in and put in an hdmi cable, and everything is working except the screen that is still the same, in fact I'm sending this message from the macbook.
You know what it might be?
New Photos:
This is the code you asked me for: 820-5482-A
답변되었습니다! 답변 보기 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 0
댓글 달기
답변 4개
선택된 답변
'''++Facundo Panizza++'''  you do want to go ahead and check the parts on your board. You need to get to the logicboard so follow this guide to get there.Use this guide MacBook Pro 15" Retina Display Mid 2015 Logic Board Replacement for that. Check the board and see if it has an 820-XXXX number on it. this is important since there are a few variations. Take some good pictures of your board etc. and post those with your question. That will allow us to see what you see. Use this guide 기존 질문에 이미지 추가하기 for that. Check the display cable to ensure that it is properly seated and that the connector is not showing any damage on the pins. Then you want to start by checking the backlight fuse for continuity and check if you have power going to it. This will be tricky since you are going to power the computer on. Do not shorten other components out while testing it. Let us know what you find.
If unsure of doing any of this contact the experts @reecee and @tcrs_circuit to see what their take is on this and if they can help you further.
iFixit 이미지
안내서
기존 질문에 이미지 추가하기
난이도:
아주 쉬움
2 - 5 minutes
MacBook Pro 15" Retina Display Mid 2015 Logic Board 이미지
안내서
난이도:
어려움
1 - 3 hours
해당 답변은 도움이 되었습니까?
점수 3
댓글 6개:
I'm sorry for the long delay, I leave the data you had asked me hopefully serve something, not get to see any corrosion, just a few stains near the load pin
I think the 9700 fuse is not walking, because I used the multimeter and gives me 0, to use it with other fuses, gives me varied numbers
Facundo Panizza do not worry about any numbers. Just check it for continuity https://www.swe-check.com.au/pages/learn...
Well, it didn't give 1, say 0.00.
okay sounds like a bad fuse. Replace it and check the circuit since something caused the fuse to blow. Check your connector make sure there is no corrosion or damage on it.
댓글 1개 더보기
댓글 달기
You’ll need to check the backlight fuse and you might need a new backlight LED driver chip as these tend to fail.
해당 답변은 도움이 되었습니까?
점수 1
댓글 달기
Hi Facundo,
To me it sounds like your backlight went out on your Macbook. I would look into a possible replacement, but before you order another one. I would check into seeing if it just came unplugged or the cable for it went bad. That way you do not waste your money on another screen if that was not the problem.
Best Regards,
Drew.
해당 답변은 도움이 되었습니까?
점수 -1
댓글 1개:
@takkaz what kind of backlight would you purchase for this and which cable may have gone bad?
댓글 달기
Screen light is burned out or inverter is out.
Will need repairing by a technician.
해당 답변은 도움이 되었습니까?
점수 -1
댓글 4개:
@charlied139 where is the inverter for this model and which screen light may have burned out? Can you elaborate on your answer?
@oldturkey03 Nice question =;)
@arbaman thank you for your support and for our great participation on our forum. You are an asset to the community!
@oldturkey03 Thanks a lot for the kind words, I really appreciate :))
댓글 달기
귀하의 답변을 추가하세요
Facundo Panizza 님은 대단히 고마워 할 것입니다.
조회 통계:
24 시간 전: 3
7일 전: 3
30일 전: 6
전체 시간: 2,078
