no spark firing opel kaddet
Hi,
I ve got a 200is kaddet with an import engine code XEV. The car has no spark at all, the following has been changed so far: Crankshaft position sensor, fuel pum relay, ignition coil.
What can cause a no spark condition in these cars? car is doing 300 000km on the clock.
좋은 질문 입니까?
댓글 6개
Phelele Mazibuko can you let us know again what year your Opel Kadett is and possibly what engine size? What have you checked so far?
oldturkey03 의
Its a 1998 year model, 2litre engine. Distributor less engine.
Changed the following:
Crankshaft sensor, fuel pump relay, ignition coil + leads.
Phelele Mazibuko 의
You changed those parts because it did not have spark? It still has no spark so none of that made a difference? Ty to scan the ECU and see if you get any codes?
oldturkey03 의
Will have it scanned on this comming weekend and let you know the codes.
Can a bad/failed engine knock sensor cause a no spark condition?
Phelele Mazibuko 의
any help cz i have the same prob with my 1996 opel astra 1.6ie ... no spark
Lebogang Lesokwane 의
댓글 1개 더보기
