주요 콘텐츠로 건너뛰기
6s와 유사한 하드웨어 사양의 4-inch iPhone은 2016년 3월에 출시되었습니다. 16/64GB 저장 옵션 및 은색, 스페이스 그레이, 금색 또는 로즈 골드로 제공됩니다. 모델 A1662 및 A1723.
1049 질문 전체 보기
Replaced battery now bottom of the screen acts unresponsive
Hi all,
Yesterday i replaced a iPhone SE battery. Everything went well but after putting everything back in the screen works, except for a small piece of the bottom. Its right at the place where the spacebar is located etc. The screen is original.
I've took everything out en back in like 10 times but it still wont work. Rest of the screen is working perfectly. What could be the problem did i damaged some kind of flex cable? must say the battery fitted really tight between the frame en logic board, could that be the problem, cause i cant remember if the original battery fitted that tight as well.
이 질문에 답하기 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 1
댓글 1개:
I think it is a hardware issue on the motherboard.
댓글 달기
답변 1개
You might have to replace the lcd again ... screen has dead pixels
해당 답변은 도움이 되었습니까?
점수 0
댓글 2개:
Replaced the screen, didn’t work. Could it be the battery?
that battery not suppose to cause that problem because the device is coming like normal
댓글 달기
귀하의 답변을 추가하세요
Pascal 님은 대단히 고마워 할 것입니다.
조회 통계:
24 시간 전: 1
7일 전: 1
30일 전: 1
전체 시간: 80
