주요 콘텐츠로 건너뛰기
4세대 iPhone의 CDMA 버전. 수리는 간단하지만 앞면 유리와 LCD를 하나의 유닛으로 교체해야 합니다. 16 또는 32GB / Model A1349 / CDMA 호환성.
295 질문 전체 보기
Why did I lose the ringer mute and volume + and - button functionality
I just bought a new battery and the tools to replace it from ifixit and that went ok but I lost the function of the ringer mute and volume buttons on the side of the phone. Is there something in the battery replacement process (everything seemed to go without a problem) that could cause this?
이 질문에 답하기 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 0
댓글 달기
답변 1개
Hi Joseph, I would verify that all connections are being made correctly. Try disconnecting the battery, power draining the device by holding the Sleep/Wake button down for 5 seconds, check LCD, and Audio cable connections, and then reconnect the battery. Check to make sure that the flex was not damaged during the process by either heat or knicked by a pry tool. I hope this helps you out.
Best of luck, Alec
해당 답변은 도움이 되었습니까?
점수 0
댓글 달기
귀하의 답변을 추가하세요
Joseph Wolf 님은 대단히 고마워 할 것입니다.
조회 통계:
24 시간 전: 0
7일 전: 0
30일 전: 1
전체 시간: 27
