주요 콘텐츠로 건너뛰기
Apple iPhone 5s는 2013년 9월 10일에 발표되었습니다. 수리는 이전 모델과 유사하며 스크류 드라이버 및 비집는 도구가 필요합니다. GSM 또는 CDMA / 16, 32, 또는 64GB / 은색, 금색 및 스페이스 그레이.
3530 질문 전체 보기
replaced battery, phone turns on apple logo, off of 10seconds, back to
Replaced battery, phone turns on apple logo, off of 10 seconds, back to apple logo and continue to keep doing this until I hold power button and home button down, phone then will shut off. when I turn it back on, it repeats the same thing over and over. checked all connectors. nothing helps. Richard
답변되었습니다! 답변 보기 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 0
댓글 1개
many, many thanks!!!!!
댓글 달기
답변 2개
선택된 답변
With the iPhone 5s, it's common to accidentally damage the front camera flex cable, especially if you didn't completely remove the screen during the battery replacement. Another common thing to check is the home button connector, if either of these things isn't fully connected, it will cause the phone to bootloop.
I work in a cell phone repair shop and can understand the frustration of changing a battery and then finding the phone no longer turns on properly. We encounter this pretty commonly, and the good news is that it's rarely unrepairable.
해당 답변은 도움이 되었습니까?
점수 1
댓글 달기
가장 유용한 답변
It could also be you're replacement battery. Have you tried re-installing the original battery to see if the phone powers up properly?
If it doesn't work with the original battery, then you probably damaged something. The iPhone 5S is also subject to pry damage along the edge of the logic board, facing the battery. If you had to pry the battery out, this could be what happened. Take a close look, preferably with magnification to see if any parts were damaged.
해당 답변은 도움이 되었습니까?
점수 2
댓글 달기
귀하의 답변을 추가하세요
Richard Swank 님은 대단히 고마워 할 것입니다.
조회 통계:
24 시간 전: 0
7일 전: 1
30일 전: 1
전체 시간: 50
