주요 콘텐츠로 건너뛰기
일반적으로 통합 스크린을 포함하지 않은 이동하지 않는 컴퓨터입니다.
2134 질문 전체 보기
The use of anti-static mats
Hi,
I'm building a PC and I was wondering if all I needed to have to make sure I don't get zapped is using just those anti-static mats, instead of the wrist strap? Is just having the anti-static mat okay or will I need the wrist strap too? Or perhaps ditch the mat and just using the wrist strap would be a better idea? FYI, I am fully aware of the discussion going around on how the equipment just makes it more safer, and the tip on attaching the wrist strap to the fan grill of the power supply, whilst having the power supply attached to a wall outlet (and the power supply switched off).
Thanks.
답변되었습니다! 답변 보기 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 0
댓글 달기
답변 1개
선택된 답변
Hi,
My $0.02 worth.
It’s not a case of you getting zapped it’s more a case of the sensitive equipment being protected from the static build up in your body discharging through it and damaging it, when you handle it during installation, e.g. handling boards, cards, modules etc incorrectly and actually touching the components on them etc. rather than holding them by the edges.
Just walking across a carpeted floor can build up a huge amount of static electricity in the body. Being connected to Earth via a wrist strap discharges this build up of static electricity.
Using both a wrist strap and an anti static mat covers all contingencies. Although you could probably get away with just a wrist strap as you'll be handling the components of the PC during the build and they should remain in their protective packaging until you are ready to individually install them.
Connecting the wrist strap to the PC case chassis (bare surface for good electrical connection - not painted surface) makes it convenient to use (with the power cord plugged in but not switched on), as long as you've verified that the outlet is Earthed correctly.
해당 답변은 도움이 되었습니까?
점수 3
댓글 달기
귀하의 답변을 추가하세요
Jeongwoo CHOI 님은 대단히 고마워 할 것입니다.
조회 통계:
24 시간 전: 0
7일 전: 1
30일 전: 2
전체 시간: 745
