My Televesion is 2 years old Picture failed. How to get it repaired.
My Sony Bravia television Model KLV323X350 is out of order. Picture was jumping and later on, no picture on screen. TV is 2 1/2 years old. How to get it repaired
좋은 질문 입니까?
좋은 질문 입니까?
sankarmandal5661 Sony uses the power LED as a troubleshooting light. Let us know if your power LED blinks and if so, how often. You also need to let us know if you have sound and if you have tried all different input sources like HDMI, Coax etc. After that you may have to remove the back of your TV. Check all the boards for obvious damage like charred, missing components or domed leaking capacitors etc. Post some good images of all your boards with your question. That way we can see what you see. Use this guide 기존 질문에 이미지 추가하기 for that. You will need a multimeter to check power outputs etc. If you follow the troubleshooting guide and no backlight turns on then the most likely failure is your B-board (main board)
해당 답변은 도움이 되었습니까?
The most common failure of these is with the capacitors in the power supply. If you are comfortable with soldering, you can replace the defective components to repair this. Open up the back and look to see whether or not there are bulged parts on the power board. If so, replace them. If not, take a few photos of the boards and post them here.
해당 답변은 도움이 되었습니까?
24 시간 전: 1
7일 전: 1
30일 전: 3
전체 시간: 54
댓글 1개
Verify your model number. Sony does not seem to have a KLV323X350 but has a KLV-32BX350.....
oldturkey03 의
