주요 콘텐츠로 건너뛰기
6s와 유사한 하드웨어 사양의 4-inch iPhone은 2016년 3월에 출시되었습니다. 16/64GB 저장 옵션 및 은색, 스페이스 그레이, 금색 또는 로즈 골드로 제공됩니다. 모델 A1662 및 A1723.
1049 질문 전체 보기
Lightly water damaged iPhone SE - issues with corrosion and speaker
I recently bought an iPhone SE from eBay in a lot of devices. The iPhone SE works, except there is corrosion near the battery connector, and the loudspeaker does not work.
The corrosion is in a small area to the right of the battery connector, it doesn't seem to cover any important components.
I was worried the audio IC was busted, but the earpiece and headphones work, so it seems to be a problem with the speaker itself.
I intend on saving the phone, because the water seemed only to affect the lower third of the phone. I replaced the loudspeaker with one from a working iPhone 5S, but the issue still continues.
In short, how do I tackle these problems and prevent the phone from further damage?
답변되었습니다! 답변 보기 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 0
댓글 달기
답변 1개
선택된 답변
how does the contacts look for the speaker on the charge port? Are they corroded? I would replace the charge port also as water can damage the wiring inside the charging dock connector!
해당 답변은 도움이 되었습니까?
점수 0
댓글 달기
귀하의 답변을 추가하세요
Eric Zhang 님은 대단히 고마워 할 것입니다.
조회 통계:
24 시간 전: 0
7일 전: 0
30일 전: 0
전체 시간: 145
