ink pad finished its service life
ink pad in epson xp-620 has finished its service life what can i do?
좋은 질문 입니까?
좋은 질문 입니까?
Hi,
Here’s a link that explains how you can temporarily continue to use the printer, but you really need to clean the waste ink pads and then reset the printer’s waste ink pad counters, to get it working again.
Here’s a link to a video that shows how to clean the waste ink pads in an Epson XP printer (hopefully it is the same for your particular XP model).
As suggested in the video after cleaning the waste ink pads you need to reset the counters.
Go online and search for Epson XP-620 reset waste ink counters to find results for suppliers of the reset software which you can purchase online
해당 답변은 도움이 되었습니까?
A printer's ink pad is at the end of its service life.
Please contact Epson Support.
I used a the WIC Reset Utility with the trial key - "trial" - from https://www.wic.support/ and it worked. This resets the waste ink counter to 90% and the printer came back to life.
Here is an excellent video how to replace the ink pads on the Epson XP-720 / XP-750: https://www.youtube.com/watch?v=yfQe5eDh...
wic reset is the best as above by david!!!!!
I managed to reset mine using https://codeberg.org/atufi/reinkpy
It's a free and open source Python program
It supports several Epson models:
ET-2600, ET-2650, ET-2720, L355, L4160, SX400, XP-55, , XP-205, XP-315, XP-422,
XP-435, XP-510, XP-530, XP-540, XP-610, XP-620, XP-630,
XP-700, XP-760, XP-830, XP-850, XP-2150, XP-7100
I also replaced the ink pads with ones I found for cheap on Aliexpress: https://www.aliexpress.com/w/wholesale-e...
Screw Epson for the lack of support/transparency and all the third-parties taking advantage of this to charge people for using products they already own.
Screw companies that design products for the landfill, so they can make more money.
24 시간 전: 30
7일 전: 265
30일 전: 1,255
전체 시간: 83,635
