주요 콘텐츠로 건너뛰기
Repair guides and support for televisions manufactured by Sony.
20 질문 전체 보기
Image Issues Blue Lines os screen
Hi Guys
I have a Sonvy Bravia model KDL-50W685A that i bought at 2013 . Suddenly the screen initially start to have pixels randmly like when loos the HD Signal . but after that shows horizontal blue lines . The sound working ok and the channels change also .
I try to recycle the power and i leave it all night closed but this is not solve my problem .
I attach the photo with the problem .
Any ideas would be appreciated .
Update (07/07/2018)
Hi to all
I reseat all the cables for the board to panel bust still the same issue .
이 질문에 답하기 저도 같은 문제가 있습니다
좋은 질문입니까?
점수 0
댓글 1개
@costasc
please attach some pictures of what your screen shows. Use this guide 기존 질문에 이미지 추가하기 for that.
Horizontal lines are almost exclusively a panle fault. Once we see what your panel shows we can hopefully get you a better answer.
댓글 달기
답변 2개
가장 유용한 답변
I would suspect poor connections to the panel. Open up the TV and re-seat all of the cables. Start there and update this with the results.
이 답변이 도움이 되었나요?
점수 1
댓글 2개:
Hi Dan
Just to clarify , you mean the connection inside the tv and not the aerial cable
That is correct. Since the signal level between the logic board and the panel is so small, it does not take much corrosion or dirt to cause a problem. Simply removing the cable and reinserting it often will "cure" the problem.
댓글 달기
@costasc
that could be a main board issue as well as a panel issue. I would start with the main board, checking the t-con board as well. disconnect all teh wiring form the T-con board to the panel. then just connect one side. Let us know what it shows.
이 답변이 도움이 되었나요?
점수 1
댓글 달기
답변을 추가하세요
Costas 영원히 감사할 것입니다.
조회 통계:
지난 24시간: 0
지난 7일: 1
지난 30일: 1
전체 시간: 176
