주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
구글 픽셀은 2016년 10월 20일에 출시된 구글의 첫 번째 플래그십 스마트폰입니다. 5인치 AMOLED 디스플레이 장치에는 32GB 및 128GB 스토리지 옵션이 제공되며 베리 실버, 콰이트 블랙, 리얼 블루의 세 가지 색상으로 제공됩니다.
LCD Display unresponsive black screen issue
Ok, so one day I decided to tear down my google pixel so I can change the battery (It needed to be done). While taking out the top portion of the screen, I had dug in far too much and cracked the LCD screen in several points. Knowing the potential harm I have already done, I proceeded to go to the battery just so I can attempt to finish the task I had at hand. After reassembling the phone (surprisingly) it didn't display any type of information, or show any signs of touch response. What I did notice is that the power button and the finger scanner on the back have responded well. To get to my question, I wanted to ask if the issue I am dealing with is solely an LCD replacement issue or did I screw up my phone to the point where I need repairs out the wazoo?? I'll appreciate any feedback!
답변되었습니다! 답변 보기 저도 같은 문제가 있습니다
좋은 질문입니까?
점수 1
댓글 달기
답변 1개
선택된 해법
You will need to replace the screen assembly. When the inner layer (LCD display layer) gets cracked the phone will not display any image which is unfortunately how OLED displays are.
Looks like the only issue is just the screen as you can tell the phone is on.
Here is guide and parts from iFixit it needed:
Google Pixel Display Replacement
Google Pixel Screen
Google Pixel Display Adhesive
For future reference and to help others when you want to remove glued in screens like the Pixel / Moto only pry in as much as the width of the adhesive for where you are prying and avoid flexing the glass / screen assembly as that is how lots of them get damaged.
A good guide is looking at YouTube videos of people opening up these phones. That way you know exactly how much you can pry in without needing to pry / push into the LCD.
Thin plastic flexible cards, heating the screen (80°C) and isopropyl alcohol on the card is the best way to lift up adhered screens.
Replace a screen compatible with Google Pixel 1st Generation model smartphones. 5.0 inch AMOLED 1180 × 1920 display and front glass digitizer. 이미지
제품
Google Pixel Screen
$59.99
This custom cut adhesive film secures the front glass digitizer screen to the midframe assembly of the Google Pixel. 이미지
제품
이 답변이 도움이 되었나요?
점수 6
댓글 달기
답변을 추가하세요
Michael Radwanski 영원히 감사할 것입니다.
조회 통계:
지난 24시간: 0
지난 7일: 5
지난 30일: 23
전체 시간: 1,521
