주요 콘텐츠로 건너뛰기
모델 번호 A1238 / 80, 120, 또는160GB 하드 드라이브 / 검정색 또는 은색 금속 외형
904 질문 전체 보기
Is my hard drive disc repairable?
My iPod classic 160 GB stopped working randomly (not after a fall or smth).
I tried formatting it but it always stops on random songs when synchronising.
It can actually still hold and play about 4500 songs, and some more but some of them can't play. The other ones won't even synchronise.
I checked and I have 5200 reallocs and 176 pending sectors.
Is this disc drive beyond repair and should I just try installing another one or is there anything I can try with this one on software or physical level?
답변되었습니다! 답변 보기 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 0
댓글 달기
답변 2개
선택된 답변
Rather than just doing a simple reformatting, try erasing the drive and use the security option of writing zeros. This will map of any bad blocks and note them in the directory so they will not try to be written to.
UPDATE
To do this go to Disk Utilities > click on the drive you want to erase> In the box that shows up click on the box in the lower left corner called Security Options > move the little shield to the left away from Fastest > run it.
해당 답변은 도움이 되었습니까?
점수 3
댓글 1개:
How do I do the security option? can't seem to find it anywhere, thanks for the answer!
댓글 달기
This kind of diagnostic data and performance usually suggests major crashes inside the drive casing, it will keep escalating.
Just get a newer drive if it is available. It is not possible to repair a hard drive mechanically.
해당 답변은 도움이 되었습니까?
점수 1
댓글 달기
귀하의 답변을 추가하세요
stef.kuypers 님은 대단히 고마워 할 것입니다.
조회 통계:
24 시간 전: 1
7일 전: 2
30일 전: 11
전체 시간: 800
