주요 콘텐츠로 건너뛰기
Paired telescopes that allow a user to see really far!
5 질문 전체 보기
The object viewed is doubled
when i look through my Bausch & Lomb binoculars the viewed object does not appear as a single object but doubled. Or in other words the two lenses are not lining up so when you look at the single object you are viewing you see double vision instead where the object overlaps. Can this be repaired. This set of binoculars is almost brand new and I suspect they were maybe dropped which knocked the viewing alignment out. thank you for your help.
이 질문에 답하기 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 1
댓글 1개
And where do you buy such binoculars?
댓글 달기
답변 4개
가장 유용한 답변
Hi @conch70 ,
As they are “almost brand new” I suggest that you consult the warranty statement that is usually found in the User Manual that should have come with the binoculars, as to what you have to do to make a claim for a manufacturer’s warranty repair or replacement.
According to this User Manual, in the USA and Canada, there is a ''lifetime limited warranty'' on the product by the manufacturer, subject to conditions obviously. Hopefully it is the same where you are.
해당 답변은 도움이 되었습니까?
점수 2
댓글 달기
The problem is that binoculars are not in collimation. This might have happened if they got dropped or knocked, but may also have been this way when bought. did you check them? Outside, In daylight?
re-collimating is not for the faint of heart, and no conditional alignment is not the same thing.
If new take them back under warranty, good luck if you dropped them
해당 답변은 도움이 되었습니까?
점수 0
댓글 달기
Being a fanatic outdoor lover, I have used numerous types of binoculars. You must maintain your binocular for better durability and service. Before buying the binocular I read this awesome guide on binoculars under 200 I've tried to find out what might cause this, but a google search only takes me to the condition of having double vision, which I don't. I only experience this while looking through our binoculars.
해당 답변은 도움이 되었습니까?
점수 0
댓글 달기
What causes it, is that one of two events have occurred.
1.The prisms have shifted in the mountings
or
2.one or other of the doublets have been rotated out of optical alignment.
The main reason for this is that they have received a severe knock at some stage.
It is possible that they came from the factory like this, which is a different issue.
해당 답변은 도움이 되었습니까?
점수 0
댓글 달기
귀하의 답변을 추가하세요
michael ferguson 님은 대단히 고마워 할 것입니다.
조회 통계:
24 시간 전: 0
7일 전: 1
30일 전: 10
전체 시간: 397
