주요 콘텐츠로 건너뛰기
Hybrid notebook/tablet released in December 2015. Manufactured by Acer, the Chromebook R11 is an inexpensive option among an already-cheap line of notebooks.
18 질문 전체 보기
How do I repair my touch screen?
I dropped my acer r11 chromebook and now my touch screen does not work.
How do I repair it?
이 질문에 답하기 저도 같은 문제가 있습니다
좋은 질문입니까?
점수 10
댓글 5개
a couple of days a go my laptop screen stoped working help
Yesterday I logged on to my Acer R11 to do something and the touchscreen wouldn't function properly it still registered but it wouldn't work right, it was dropped 5 days ago but still worked fine afterward so I don't think that had anything to do with it, and it is not even 2 weeks old, I hope I don't have to replace it.
I dropped mine during class and grabbed it right away. I found that I could not use the touchscreen but I could still use the stylus and the keyboard. And now while seeing how to fix it I somehow disabled the touchpad. This is the Chromebook pro by samsung.
how did you fix it?
my acer chromebook r 11 fall touch screen not work
댓글 달기
답변 8개
가장 유용한 답변
You can try disassembling the laptop and check if the connection between the motherboard and touchpad is loose. It is possible that the connection got loose because of the bump/hit. Else, the touchpad maybe damaged, and in this case, you need to contact a repair technician.
이 답변이 도움이 되었나요?
점수 3
댓글 1개:
Where is the motherboard once you dissassemble it?
댓글 달기
this is a replacement Digitizer.
https://www.laptopscreen.com/English/mod...
This is unfortunately a video of the Acer Aspire R11, hinge replacement, so some screws may be different, but the concept is the same. so the skillsets are transferrable.
https://www.youtube.com/watch?v=nzAmaOuc...
Be sure to keep the adhesive as warm as you can to allow for easier removal.
이 답변이 도움이 되었나요?
점수 2
댓글 달기
At previous days my laptop touch is not working
이 답변이 도움이 되었나요?
점수 2
댓글 달기
maby go to a laptop fixer place or reset the laptop
이 답변이 도움이 되었나요?
점수 1
댓글 달기
It is likely a hardware fault.
Check if the connection between the motherboard and touchpad is loose.
이 답변이 도움이 되었나요?
점수 1
댓글 달기
If there is no break or burning in the screen, you can relax in the screen clips. You should open the device and put the dog in its proper place. If you can not do this, you should go to the mobile maintenance mechanic
이 답변이 도움이 되었나요?
점수 1
댓글 달기
this is a hardware breakdown issue. I would say to bring it in to an expert.
이 답변이 도움이 되었나요?
점수 1
댓글 달기
If your a personal user and not a student I would look for the repair guide or take apart the device and get the serial number or part number of the device. Look it up and order the part. When repairing make sure the battery is unplugged this is extremely important. If your not comfortable I would take the device to a repair technician. Screens are really the easiest thing to fix.
이 답변이 도움이 되었나요?
점수 1
댓글 달기
답변을 추가하세요
Dennis Bolestridge 영원히 감사할 것입니다.
조회 통계:
지난 24시간: 0
지난 7일: 4
지난 30일: 5
전체 시간: 4,445
