주요 콘텐츠로 건너뛰기
2009년 3월에 소개된 The Mac Pro (Early 2009)는 Intel Nehalem 아키텍처를 Apple의 전문가용 데스크탑 라인에 도입하였으며 미묘하게 재설계된 내부는 2010 및 2012 CPU 업데이트를 통해 소개되었습니다.
202 질문 전체 보기
Mac Pro 2009 but 5,1 + Radeon 7950 no Mojave Metal - slow
Hi there
I've got Mac Pro 2009 flashed to 5,1 (to natively support High Sierra) - I've purchased Radeon 7950 because been told it is supporting macOS Mojave - and.... sorry - but got slow window animation "washed" white/grey colours like I've seen somewhere on youtube on unsupported Mac (I think 2008).
7950 is EFI flashed.
Mojave Public Beta 2
So what's wrong?
이 질문에 답하기 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 0
댓글 달기
답변 2개
가장 유용한 답변
Your other problem may be that the High Sierra and/or Mojave has messed up your hard drive formatting if you have upgraded to an SSHD or SSD. I have the same machine, flashed to 5.1 with DosDude, but I only took it to Sierra. Running a 512 SSD as my boot drive.
Also MS Office 2011 will slow you down to a slow crawl with High Sierra and/or Mojave.
해당 답변은 도움이 되었습니까?
점수 4
댓글 달기
Go into About this Mac > System Report. Jump down to ‘Graphics/Displays’ section click on the GPU and look for the heading ‘Metal’ in my MacBook Pro 2012 system I see ‘Supported, feature set macOS GPUFamily1 v3’ Yours should say something similar if it supports Metal.
You may only need to update the GPU drivers to get it to work.
해당 답변은 도움이 되었습니까?
점수 2
댓글 2개:
Here is a tester for Sierra or High Sierra to test the GPU netkas.org - Metal supported GPU
Fabulous. This really matters, now that Mojave is out.
댓글 달기
귀하의 답변을 추가하세요
Bart 님은 대단히 고마워 할 것입니다.
조회 통계:
24 시간 전: 1
7일 전: 3
30일 전: 4
전체 시간: 598
