주요 콘텐츠로 건너뛰기
Clothes dryer repair and support guides.
871 질문 전체 보기
My kenmore dryer 81122 has Rotating blinking lights.
i put the dryer recently on normal 1 hour cycle , no wrinkle guard and after a few minutes it shows rotating blinking lights. Sometimes it stops mid cycle. There is no wrinkle guard on . It never did this before, first time! Can anyone tell me what is wrong with the dryer.
이 질문에 답하기 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 0
댓글 1개
I have same issue for kenmore dryer
Anyone found solution to this?
댓글 달기
답변 3개
가장 유용한 답변
Rotating blinking lights in the display is probably an indication that the Wrinkle Prevent option has been selected. Wrinkle Prevent will continue to tumble the dryer without heat after the cycle has ended to help prevent wrinkles from setting in. When this option is selected by pressing the Wrinkle Prevent button on the control panel, the display will count down the estimated cycle time; when the cycle ends, the display will show lights blinking in a circular (or actually rectangular) motion.
To deactivate, simply press the Wrinkle Prevent button again so the light is not illuminated.
해당 답변은 도움이 되었습니까?
점수 2
댓글 2개:
The light is not illuminated. i posted the video showing the wrinkle prevent was off. yesterday the dryer did the rotating blinking lights again and stopped before the cycle was over.
I have the very same problem, the dryer works only for a few minutes and then shows rotating lights and some time later has 3 blinking lights. Clothes are still wet
댓글 달기
I found that one pin of the 3 pin power lead (110 VAC) was partially damaged, perhaps not proiding enough current for heating. After the lead was replaced the dryer has been working perfectly.
Jolanta
해당 답변은 도움이 되었습니까?
점수 0
댓글 달기
Yeah, because the dryer has a choice, when Wrinkle Guard is off, when your dryer gets to cool down mode, it now shows 10 minutes left
When Wrinkle Guard is on, when you dry finishes with the drying cycle and wrinkle guard is on your dryer stays on, but if wrinkle guard is off and when your dryer finishes cool down mode, then your dryer stops working.
해당 답변은 도움이 되었습니까?
점수 0
댓글 달기
귀하의 답변을 추가하세요
JANET DEJESUS 님은 대단히 고마워 할 것입니다.
조회 통계:
24 시간 전: 10
7일 전: 17
30일 전: 43
전체 시간: 1,651
