주요 콘텐츠로 건너뛰기
The 2014 edition of the Kindle, part of the 7th generation, includes a touchscreen and same form-factor as the Kindle Paperwhite, but lacks the backlight.
29 질문 전체 보기
How can I change my language from Chinese back to English?
My Kindle is stuck in Chinese Mode and can’t work out how to change it to English.
이 질문에 답하기 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 11
댓글 2개
still does not solve problem. Stuck in chinese. All in chinese. no home, menu or settings
I wonted to change my kindle language from chines to English but the chines langu it’s hard to me
댓글 달기
답변 9개
가장 유용한 답변
Here’s answer -
If you don’t have ads - may be different list items for with adds…
home (house) top left
Menu top right 3 dots
2nd from bottom (settings)
look for the globe - 5th down list
first one in list is language
That should be it
this took me hours to figure after my 4 year old swiped my new kindle and used it as a phone
If they change the order play around until you find the globe - then try every item in that list until get language.
해당 답변은 도움이 되었습니까?
점수 13
댓글 6개:
Once you get to settings and language, every option is AGAIN written only in Chinese! You have to pick the correct one before you can set the language. this can be done only by guessing and trial and error, which is what you have to do. It needs to not be so easy to accidentally set the language in the first place. It shouldn't be possible to do it by accidentally swiping something (or however it even happened) when you first take the Kindle out of the box. Especially, you should need to go through multiple menus and multiple buttons before you can set the language to one with a completely different alphabet. It shouldn't be "accidental."
THANK YOU!!!! You were the only one who seemed to realize that the instructions had also changed to Chinese, so we needed the step-by-step explanation with numerical order and what pictures to look for. You saved my sanity!
Thanks! Worked perfectly for me.
Thank you. Worked for me too appreciate the simplicity
October 4
thank you so much, I would never have worked that out on my own
댓글 1개 더보기
댓글 달기
Older versions of Kindle: After clicking on settings icon then click the ‘World’ icon. From the next screen click the first item in the list. From there you will be taken to the language page. Click the dropdown arrow and choose English…third from the top.
On newer versions of Kindle without categorized menu: Click on settings icon then scroll to the bottom. Click the icon 3rd from the bottom. This icon resembles 3 sliding bars. On the next screen click the first item in the list. On the following screen click the dropdown arrow and choose English…fourth one from the top.
해당 답변은 도움이 되었습니까?
점수 3
댓글 3개:
Thank you sooo much. My 6yr old changed a brand new kindle to a different language.
THANKS !!!! I'm not very good at Chinese and with the different icon even worse lol thanks again.
@clarethommem
GIRRRL, THANK YOU SO MUCH I made an account here just to up vote you and thank you. You kept me from doing a factory reset. 😍😍😍😍😍😍😍😍
댓글 달기
I posted this is a comment on someone else’s post, but in case anyone else is trying to find out how to do this and doesn’t read each post… here it is as a main post.
Once you get to settings and language, you still haven’t finished going through the maze— every additional option is AGAIN written only in Chinese! You have to pick the correct one before you can set the language. This can be done only by guessing and trial and error. I don’t know who Amazon thinks has the time for this. It could be solved by not making it so easy to accidentally set the wrong language in the first place. It shouldn't be possible to do it by accidentally swiping one thing (or however it even happened) when you first take the Kindle out of the box. Especially, the user should need to go through multiple menus and multiple buttons before you can set the language to one with a completely different alphabet. It shouldn't be so hard to avoid initially doing this by accident. Thirty seconds extra of thinking about usability on the engineers’ part would have kept this problem from ever coming up. So why didn’t they… why am I even asking why Amazon would have spent thirty seconds thinking about the user’s experience!!
해당 답변은 도움이 되었습니까?
점수 2
댓글 달기
Hi,
I just had this happen to me. I bought a refurbished kindle paperwhite from Woot and when I started it up, it was in Chinese. I found a simple solution (if you have an iphone), use the google translate app, in camera mode, and point it at the screen. I could navigate through the settings to switch the language.
Cheers,
Jim
해당 답변은 도움이 되었습니까?
점수 2
댓글 달기
I have a Lilyput 5” monitor that changed changed Language to Chinese
could you please let me know how to change it back to English it would help me if you could show a video / picture of the monitor and what buttons to press to achieve success.
I’d be so grateful for your help Roy 25-11-21
해당 답변은 도움이 되었습니까?
점수 1
댓글 달기
I have a. Lilyput 5” field monitor that’s gone Chinese how do I get it back to English
해당 답변은 도움이 되었습니까?
점수 0
댓글 달기
I was also able to navigate it by pointing my phone's camera at the screen using Google translate to auto detect and translate the screens!
해당 답변은 도움이 되었습니까?
점수 0
댓글 달기
I have been struggling with the language change as I use Google Chrome. Thank you for helping me too.
해당 답변은 도움이 되었습니까?
점수 0
댓글 달기
I used the auto translate function in google on my phone. It 'took' a picture of the kindle screen and translated everything to english, so I could make the correct selections in the menus.
해당 답변은 도움이 되었습니까?
점수 0
댓글 달기
귀하의 답변을 추가하세요
jameskcateresq 님은 대단히 고마워 할 것입니다.
조회 통계:
24 시간 전: 6
7일 전: 42
30일 전: 226
전체 시간: 29,265
