주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
The Ram line was redesigned for the 1994 model year. Development on a second generation began in 1986, ending in late 1992.
Computer malfunction, reset possible?
The main snap together wiring was removed while the engine was running. Now runs super retarded. can I reset?
이 질문에 답하기 저도 같은 문제가 있습니다
좋은 질문입니까?
점수 0
댓글 달기
답변 1개
With the engine off, cycle the ignition on and off 3 times quickly leaving the ignition on the last time. The odometer will display the codes in the PCM. f the codes are not active you may be able to clear them with the odometer reset button. If this does not work you will need a OBD scan tool to clear the codes.
이 답변이 도움이 되었나요?
점수 0
댓글 달기
답변을 추가하세요
Jack Heringer 영원히 감사할 것입니다.
조회 통계:
지난 24시간: 1
지난 7일: 7
지난 30일: 45
전체 시간: 500
