Computer malfunction, reset possible?
The main snap together wiring was removed while the engine was running. Now runs super retarded. can I reset?
좋은 질문 입니까?
좋은 질문 입니까?
With the engine off, cycle the ignition on and off 3 times quickly leaving the ignition on the last time. The odometer will display the codes in the PCM. f the codes are not active you may be able to clear them with the odometer reset button. If this does not work you will need a OBD scan tool to clear the codes.
해당 답변은 도움이 되었습니까?
24 시간 전: 1
7일 전: 1
30일 전: 6
전체 시간: 135
