주요 콘텐츠로 건너뛰기
This PC is a Dell Inspiron 3000 Series laptop with an AMD processor and a non-touch display. It's model number is 3541.
Laptop will not power on
I have a Dell Inspiron 3451 with touch screen and 1T of memory. Used it and it was running fine. Closed it for the night. Next day went to use it and got nothing. Push power button I get nothing. Hold power button down, can here it starting up then screen flashes on for a second then goes off. Plug it in and charing light does come on then after a while starts blinking. Please help!!!
이 질문에 답하기 저도 같은 문제가 있습니다
좋은 질문입니까?
점수 0
댓글 달기
답변 1개
가장 유용한 답변
Hi @tngraham1979 ,
Try the following:
Ensure the laptop is turned off.
Switch off and disconnect the charger from the laptop.
Remove the battery from the laptop. (Here’s a link that shows how to do this).
Press and hold the laptop’s Power button for 30 seconds and then release.
Connect the charger to the laptop and switch it on, then turn on the laptop. (Leave the battery out at this stage).
If the laptop starts OK, allow it to boot all the way to the Windows desktop, let the HDD activity settle down a bit, then shutdown the laptop in the normal way.
When the laptop has completely turned off, switch off and disconnect the charger.
Reinsert the battery.
Connect the charger and switch it on, then turn on the laptop.
If the laptop starts OK, allow it to boot all the way to the Windows desktop, let the HDD activity settle down a bit, then check the battery charge status.
If it is charging, allow it to fully charge before switching off the charger and disconnecting it from the laptop.
이 답변이 도움이 되었나요?
점수 2
댓글 달기
답변을 추가하세요
Tia Hebert 영원히 감사할 것입니다.
조회 통계:
지난 24시간: 0
지난 7일: 2
지난 30일: 8
전체 시간: 197
