주요 콘텐츠로 건너뛰기
2011년 상반기 모델, A1278 / 2.3 GHz i5 또는 2.7 GHz i7 프로세서.
782 질문 전체 보기
Is it possible to upgrade the HDD to a SSD drive?
I recently brought a new 13" macbook pro, model no-A1278. It shipped with a 320 GB (5200 RPM) HDD. Can i upgrade it to a SSD drive ?
이 질문에 답하기 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 -1
댓글 달기
답변 2개
가장 유용한 답변
yes you can. you dont need a special connector or anything. any standard sata 2.5" ssd drive work natively. the corsair realSSD is the best i've seen, since its a sata-III drive, and your shiny new macbook pro just happens to ship with a sata-III port! those are expensive though, and honestly, in real life situations, you wont notice the speed difference between it and say, a cheapo kingston SSDNow, which you can probably find on ebay or amazon for like $150 (128gb)
해당 답변은 도움이 되었습니까?
점수 1
댓글 달기
Yes, if you get the right connector. The 240GB Vertex 2 SSD would be my first choice.
Also This Drive is a good choice as well. (just be sure that the dimensions fit)
해당 답변은 도움이 되었습니까?
점수 0
댓글 2개:
Thanks wise for ur reply. What type of connector required and from where i can get it? How much that SSD cost ?
I've read on forums that the intel SSD X25 is the best choice. Google it, it has the same connector as the standard HD. It costs $215 and its 120GB.
댓글 달기
귀하의 답변을 추가하세요
chinmayaol 님은 대단히 고마워 할 것입니다.
조회 통계:
24 시간 전: 0
7일 전: 0
30일 전: 0
전체 시간: 3,537
