주요 콘텐츠로 건너뛰기
2006 중반기/ 모델 번호 A1181 / 검정 또는 흰색 케이스 / 1.83 or 2.0 GHz Intel Core Duo 프로세서.
418 질문 전체 보기
swaping multi track pad from new macbook to old macbook
hi is it possible to swap multi track pad from new macbook to old macbook A1181
답변되었습니다! 답변 보기 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 1
댓글 달기
답변 2개
선택된 답변
I've never found an A1181 topcase/keyboard that would not work with another A1181, so if it's from an A1181, it should work on another. If you're talking about a new unibody white MacBook, that will not work, because that has a totally different model topcase/keyboard that will not fit.
Also, in case you're not aware, the topcase, pad, and keyboard are all one single piece, i.e. it is not possible to swap just the pad because it is sealed in plastic and not removable from the topcase and keyboard. It's necessary to replace the whole thing.
해당 답변은 도움이 되었습니까?
점수 5
댓글 달기
there this website that sale just the multi track pad
http://www.powerbookmedic.com/xcart1/pro...
just wondering if it can be swapped into the older macbook i seen it done somewhere but can't find it now
해당 답변은 도움이 되었습니까?
점수 0
댓글 1개:
That is the pad for the new white unibody MacBook, which is in no way compatible with the older A1181s.
댓글 달기
귀하의 답변을 추가하세요
david 님은 대단히 고마워 할 것입니다.
조회 통계:
24 시간 전: 1
7일 전: 6
30일 전: 7
전체 시간: 1,280
