주요 콘텐츠로 건너뛰기
3 MB 공유 L3 캐시 1.7 듀얼-코어 Intel 프로세서 (Turbo Boost 최대 2.6 GHz).
139 질문 전체 보기
Only turns on with AC power
I have a 2012 MacBook Air 11”. It had some wine spilled on it a while ago. I took everything out and gently cleaned it with isopropyl alcohol. It worked just fine, but the mouse wouldn't move.
Today, I took out the trackpad and gave it an ultrasonic bath in isopropyl alcohol. Now it won't turn on, except for on AC power (and even then only sometimes).
Is this related to the trackpad, or is it something different?
답변되었습니다! 답변 보기 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 0
댓글 달기
답변 1개
선택된 답변
You’ll need a new trackpad as you ruined yours in the ultrasonic. These devices can’t be cleaned using a ultrasonic as the cleaning fluid (any) will seep into the plates damaging them.
Here’s the needed part: MacBook Air 11" (Mid 2011-Mid 2012) Trackpad
MacBook Air 11" (Mid 2011-Mid 2012) Trackpad 이미지
상품
$29.99
해당 답변은 도움이 되었습니까?
점수 1
댓글 3개:
Thanks! Will this also solve the power issue?
First replace the trackpad to see where things are then.
Thanks! I replaced the trackpad and trackpad cable. This worked. Looks like something in the SMC reset circuit was messed up.
댓글 달기
귀하의 답변을 추가하세요
Buddy Guy 님은 대단히 고마워 할 것입니다.
조회 통계:
24 시간 전: 1
7일 전: 1
30일 전: 2
전체 시간: 57
