주요 콘텐츠로 건너뛰기
2015년 9월 25일 출시. Model A1688/A1633. 수리는 이전 모델과 유사하며 스크류 드라이버 및 비집는 도구가 필요합니다. GSM 또는 CDMA / 6, 64, 또는 128GB / 은색, 금색, 스페이스 그레이 및 로즈 골드로 제공하였습니다.
2690 질문 전체 보기
Advice on a component I knocked off
Hey i was hoping to get some advice, I accidentally knocked off the C0552 capacitor on an iPhone 6s when i tried unplugging a connector.. it was so small!
I wasnt originally attempting a board repair until this fell off so im worried that it might be something critical.
From what i see in the schematic its part of the “NORTH DC CURRENT BLOCKING CAPS” Screenshot: https://imgur.com/a/XIjDRMH
Thanks I appreciate all the help i can get, I’m interested to seeing what its function on the board is too :)
답변되었습니다! 답변 보기 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 0
댓글 달기
답변 3개
선택된 답변
This capacitor is pretty easy to source; you can find them at DigiKey or Mouser. Soldering them is another story however as they are quite tiny.
That said, I don’t think it needs to be replaced. These four caps are there to filter out any noise on the the NORTH_AC_GND_SCREW line which is where the antenna interconnect resides. These caps are designed in to optimize performance when manufacturing tens of millions of devices. I would try to simply rebuild the device as is and see how it performs, If you don’t see a difference, then don’t bother with it.
해당 답변은 도움이 되었습니까?
점수 2
댓글 달기
Hey Jacob
You can replace the capacitor from a 3rd party vendor, and you will have to solder the new one back on. Im not sure who carries the capacitors for the Logic Board though. The easier route would probably be just to replace the Logic Board entirely. You can find a Logic Board for your iPhone 6s inexpensively to install so you don’t have to mess with soldering components or matching individual codes and specifications.
You can try Amazon or Newegg for the Logic Board, those two would have reasonable prices. For the capacitor I’m not sure who would sell it.
Good Luck!
해당 답변은 도움이 되었습니까?
점수 1
댓글 3개:
I suppose i could find a water damaged iphone dirt cheap and see if it has a cap thats in good condition and pass it onto someone who can smd solder, I'm curious what the function of this cap is, do you know?
This capacitor is for a section of antenna's that are routed through the chassis on the northern bottom side. So it would be very difficult to solder it back on.
I would strongly suggest to replace the Logic Board itself, that would save you a ton of time and labor
댓글 달기
Here’s board view for both sides of that cap.
Thankfully it’s not located in a terribly crowded spot on the board, but still very, very tiny. Unless you have much experience with micro soldering I’d say either get it repaired by a professional board level repair shop, or replace the logic board. the phone will likely function just fine without this capacitor (as @techstuff mentioned) but it is probably safer for the phone to replace it.
해당 답변은 도움이 되었습니까?
점수 1
댓글 1개:
Exactly! better to be on the safer side rather than a dangerous side. Replacement would definitely prevent any danger such as shorts, fire, or iOS corruption.
댓글 달기
귀하의 답변을 추가하세요
Jacob 님은 대단히 고마워 할 것입니다.
조회 통계:
24 시간 전: 1
7일 전: 1
30일 전: 1
전체 시간: 99
