주요 콘텐츠로 건너뛰기
2세대 iPhone. Model A1241 / 8 또는 16GB 용량 / 검정 또는 흰색 플라스틱 뒷면. 첫 번째 iPhone보다 수리는 더 간단하며 스크루드라이버, 비집는 도구 그리고 흡입 도구가 필요합니다.
1158 질문 전체 보기
How to change the home button
is it possible to change the home button without having to remove the screen and if it is can you make a guide to it. i have a iphone and the ribbon broke to the home button so i was wanting to repair it myself to save money, can you help please
답변되었습니다! 답변 보기 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 -1
댓글 5개
What if the digitizer doesn't come with a home button
you can buy the home button or the flex separately at most online shops. before you do that just check the dock connector for dirt and dust where it makes contact with the home button prongs. also check that the prongs haven't been flattened through use...gently lift up a little using something like a flathead screwdriver.
Its just the screen everything else works
sorry, i'm not sure i understand. are wanting to replace the home button or are you worried that the digitiser has no home button?
댓글 달기
답변 2개
선택된 답변
most digitisers are sold with out the home button installed. if you want to avoid the hassle of removing the digitiser then you will need to purchase the complete display assembly.. like this iPhone 3G Front Panel Assembly
iPhone 3G Front Panel Assembly 이미지
상품
$29.99
해당 답변은 도움이 되었습니까?
점수 4
댓글 달기
No. It's not unless you want to buy a new already put together digitizer. To get the glass off you will need to heat it up, i usually use my heat gun at about 150 to 200 c.
해당 답변은 도움이 되었습니까?
점수 1
댓글 달기
귀하의 답변을 추가하세요
patrick 님은 대단히 고마워 할 것입니다.
조회 통계:
24 시간 전: 1
7일 전: 2
30일 전: 2
전체 시간: 2,525
