Enter button not working
My battery leaked acid yesterday and after cleaning it up, the calculator worked perfectly. However, today when I went to use it, every key worked except for the enter key. What can I do?
좋은 질문입니까?
좋은 질문입니까?
You can try to repair the button using this guide here. However, the corrosion may have permanently damaged the button which will require a motherboard replacement. You can’t buy new motherboards, but if you can find a calculator with damaged screen, the motherboard is still probably OK and you can salvage it out of the broken calculator. There’s a guide on motherboard replacement here.
안내서
난이도:
조정
5 - 15 minutes
안내서
난이도:
조정
10 - 20 minutes
이 답변이 도움이 되었나요?
지난 24시간: 0
지난 7일: 7
지난 30일: 15
전체 시간: 3,309
