Can I repair my adapter cable?
it is possible to reconnect the the cable to the adapter in a clean way? its giving issues and finding a replacement charger is tough
좋은 질문 입니까?
좋은 질문 입니까?
Karim Esquivel it sounds like you are talking about the AC adapter. You can remove part of the wire and resolder a new adapter. Post some pictures of where you think your wire is bad and what the adapters ends look like. Use this guide 기존 질문에 이미지 추가하기 for that so that we can see what you see.
해당 답변은 도움이 되었습니까?
I had the same problem. I could not find the same plug (connector), so I cut off the cable from the original adapter and mounted it to an universal adapter for the correct voltage. I can't remember what the exact specification was (I think it was 12V), but I can look it up if you're interested.
해당 답변은 도움이 되었습니까?
24 시간 전: 0
7일 전: 2
30일 전: 4
전체 시간: 309
댓글 1개
My adepter is not working
Sheikm Adnaan 의
