주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
GPD XD는 중국 회사 GamePad Digital에서 2015년 하반기에 출시한 안드로이드 기반 휴대용 게임기입니다. 정전식 터치 스크린 한 개가 있으며 에뮬레이터 및 기타 기본 안드로이드 소프트웨어 실행에 최적화되어 있습니다.
Can anybody tell me what type of micro USB socket I need for my GPD XD
Hi guys,
the micro USB socket of my GPD XD gaming console is broken and I would like to repair it by replacing it. But my problem is that I don’t know what type of micro USB socket i need to buy. Please see the pictures.
Can anybody help me making the right decision?
thanks a lot
이미지
이미지
이미지
이 질문에 답하기 저도 같은 문제가 있습니다
좋은 질문입니까?
점수 0
댓글 달기
답변 3개
가장 유용한 답변
Hi,
for everybody who is interested what I have done after this issue. First of all I noticed that the socket used to be smd soldered on the PCB (printed circuit board) and I could not find anyone who is able to do this rework.
Then I ordered an Micro-USB adapter cable. Cut the cable and soldered the cable on the solder points. Now I can use the device and everything is wokring fine.
Cheers
이 답변이 도움이 되었나요?
점수 1
댓글 1개:
i no undertand and i same problem ... please help
댓글 달기
@mariosolis79995, User Ayrix is saying that they managed to remove the old socket from the board and, instead of replacing it with a new socket, they took a cord with a micro USB receptacle on one end and cut the wires, stripped them and soldered the bare wires directly to the circuit board. Now, instead of having a socket mounted in the chassis, they have a cord sticking out with a socket you plug your cord into.
That avoids the problem of finding the correct replacement part since any cord will work; it doesn't have to match up with the solder pads on the circuit board like a socket would. It would actually be possible to locate a replacement part as there are literally hundreds to choose from, but the problem here is that we can see from the photos the four solder points that provide the mounting for the socket, but we can't see the five solder pads where the pins of the connector solder onto. Without knowing what those look like, it's impossible to correctly identify a replacement.
If we could locate a picture of those solder pads I'd be happy to try and find a replacement.
이 답변이 도움이 되었나요?
점수 0
댓글 달기
I picked up a pack of 100 micro usb ports on Amazon for £10. 10 different types, 10 of each. 1 of them was a perfect match with the 5 pins and the 4 main legs all in the right place. Installed one, and it worked perfectly. Not a very difficult repair if you have a little reflow experience.
이 답변이 도움이 되었나요?
점수 0
댓글 달기
답변을 추가하세요
Ayrix 영원히 감사할 것입니다.
조회 통계:
지난 24시간: 10
지난 7일: 11
지난 30일: 33
전체 시간: 769
