주요 콘텐츠로 건너뛰기
The 7th generation Honda Accord
101 질문 전체 보기
backup lights, mirrors, electric windows, not working, also stick is l
I was installing a back up camera, suddenly, backup light stop working, transmission got locked in parking gear, mirrors, windows, ac compressor, signal lights stop work as well,,,,does anyone know wich relay is damaged and its location?
이 질문에 답하기 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 0
댓글 달기
답변 1개
가장 유용한 답변
@heccxon how and where di you try to install the camera? Did you tap into any wiring harness etc? I do not think it is as easy as a single relay. To many things have stopped working that are not on one relay nor are they related. Post some images of anything that you may have cut to splice etc. Post those images with your question so that we can see what you see. 기존 질문에 이미지 추가하기
Remove the battery cable and leave it off for 15-30 minutes. Then reconnect and see what happens. Make sure that you have your radio code (if needed) before doing this.
해당 답변은 도움이 되었습니까?
점수 1
댓글 달기
귀하의 답변을 추가하세요
hed 님은 대단히 고마워 할 것입니다.
조회 통계:
24 시간 전: 0
7일 전: 0
30일 전: 1
전체 시간: 38
