주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
Repair information and troubleshooting for Craftsman-brand riding lawnmowers.
Mower will not start with key
Problems started with a motor choking with excessive gas ( removed and cleaned carb).did not cure the problem. Started the mower again and let it run at 1/3 speed and ran normally. Engaged the mower deck and choking started right away and then stopped.
After dis- engaging the deck I tried to start the mower with the key switch and it would not . Leaving the key on ,I was able to start the motor by jumping the solinode. Still choking at medium to high speed and now no deck engagement when I put up the knob on the dashboard. Also noted at this time that the running hours meter also was not working.
Would the seat safety switch cause all of this? Or the key switch?
이 질문에 답하기 저도 같은 문제가 있습니다
좋은 질문입니까?
점수 0
댓글 달기
답변 1개
가장 유용한 답변
shavorhead  all of this sounds like the key switch. It appears as if it does not close all circuits. I’d start with a replacement. If nothing else it will provide you with a know-good starting point for further troubleshooting. Also, give us the exact model number for your mower
이 답변이 도움이 되었나요?
점수 1
댓글 달기
답변을 추가하세요
shavorhead 영원히 감사할 것입니다.
조회 통계:
지난 24시간: 0
지난 7일: 0
지난 30일: 2
전체 시간: 76
