주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
Xperia Z1 Compact는 Sony의 프리미엄 카메라 스마트폰입니다. Xperia Z1 모델과 비슷하지만 더 작고 가격이 저렴합니다. 주요 기능은 20.7 메가픽셀 이미지 센서입니다. 출시 당시 사용 가능한 색상은 화이트, 블랙, 핑크, 라임이었습니다. 이 기기는 모델 번호(D5503)를 통해 식별할 수 있습니다.
Phone doesn't charge while powerded on
Hi guys
So a bit of a tricky situation here…
So recently my phone dies pretty quickly. I have it charged to 100%, it runs for a while and at around 40% or so left, it would power off (but this is not the actual problem), or so I guess)
The problem starts here (Phone battery at 0%):
As soon as I connect it to a power source, it charges for a few seconds, then the “SONY” screen appears (is it trying to boot?) and then it goes back to dark… and it is apparently NOT charging further.
So I disconnect and reconnect to the power source, but then again, it charges for a few seconds, “SONY” screen appears, it goes back to dark and stops charging.
Repeat the game.
Another interesting thing that happened:
Sometimes I do manage to turn my phone on (at 1-3% of battery), but when my phone is turned on, it does not charge although connected to the power source.
Only after it’s turned off (by running out of battery or by turning it off manually), it charges for a while, and then as written above.
So.. what’s going on here?
A few things to mention:
1. I have tried connecting to a power outlet and to my laptop (same result, also laptop doesn’t recognize the device)
2. Power cable and outlets are fully functional
3. Phone battery I guess is fully functional, especially since I bought a new one and inserted it today
My next step would be a hard reset, but then again, it will never have charged enough power to do that
Now I essentially carry a brick in my pocket :p
Also, with already 4 years of “service”, it might be that my phone has pretty much hit its life expectancy.
Any guesses?
Thanks
이 질문에 답하기 저도 같은 문제가 있습니다
좋은 질문입니까?
점수 0
댓글 달기
답변 1개
가장 유용한 답변
I’m guessing a bad charging socket on the phone which would mean getting it replaced would be required.
The charging port is soldered on the logic board so it may not be worth getting it replaced.
이 답변이 도움이 되었나요?
점수 1
댓글 달기
답변을 추가하세요
tobias_wiehl 영원히 감사할 것입니다.
조회 통계:
지난 24시간: 1
지난 7일: 7
지난 30일: 24
전체 시간: 732
