주요 콘텐츠로 건너뛰기
2012년 6월 출시 / Core i7 프로세서 Turbo Boost 포함 / 최대 1 GB DDR5 비디오 RAM
596 질문 전체 보기
New Replacement Battery, slow charging
I just bought a new iFixit battery replacement for my MacBook Pro. It’s charging very slowly. I did the battery calibration last night (charge fully, leave plugged in for 2 hrs, unplug and let the battery go to 0%, leave unplugged for 5 hrs) and am now having it plugged in to charge to 100% again.
In cocunut battery it says it is only charging from ~6-9 watts. It’s gone from 0% to 70% in 3.5 hrs, which is way slower than with my previous battery. Is the battery from iFixit defective?
답변되었습니다! 답변 보기 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 4
댓글 1개
It's been charging for ~5.5 hrs and is at 89%. The MbP says it will take another 3 hrs to reach 100%. That would be an 8.5 hr total time to charge from 0-100%.
댓글 달기
답변 1개
선택된 답변
Two main parts are involved in charging, the battery itself and the charging circuit on the logic board, thus it’s either a defective battery or something might have gone bad in charging circuit during replacement or earlier. Best thing to do here would be to reinstall the old battery for testing purposes unless it’s flat dead and see how that behaves.
That should provide the answer you need before asking for a replacement battery.
해당 답변은 도움이 되었습니까?
점수 1
댓글 1개:
I put in the old Apple battery and that one behaves normally. It got bad enough that I wasn’t even able to run my MacBook Pro if it wasn’t plugged into the wall with the ifixit battery. My MacBook Pro stopped recognizing the ifixit battery entirely. I’ve been running my original battery for the last few days with the original Apple battery and it has behaved much better. I believe something is wrong with the ifixit battery.
댓글 달기
귀하의 답변을 추가하세요
Corey Bodendein 님은 대단히 고마워 할 것입니다.
조회 통계:
24 시간 전: 0
7일 전: 7
30일 전: 15
전체 시간: 470
