주요 콘텐츠로 건너뛰기
Released in October of 2003, Sony's Cyber-shot DSC-T1 is an ultra compact camera with many great features all in a package about the size of a deck of playing cards.
6 질문 전체 보기
Misplaced Pin on Sony DSC-T1 Repair
Hi Great guide on repairing the DSC-T1's components. When I opened the front cover a small pin fell out. It is about 11mm long and the shaft is about 1mm in diameter. I do not see it pictured in any of your photos and I can't find where it goes. The camera seems to work without it, but I'd really like to know where it goes.
Thanks for your help.
답변되었습니다! 답변 보기 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 -1
댓글 달기
답변 4개
선택된 답변
Sean Mann I placed the complete level 1-level 3 service manuals for you to download. It will show you everything you ever wanted to know about your camera. May be you find the "spare part :-) " and its location. Good Luck
Level 1
Level 2
Level 3
해당 답변은 도움이 되었습니까?
점수 3
댓글 3개:
Thanks a ton man!!
You are welcome ;-)
Thanks to Old Turkey I can tell you that it's a "lens pin" and it goes into the lens/CCD assembly, just under the one motor.
On the other hand I can't tell you what it does. Looks like it just lies in there loose, doesn't hold anything, doesn't touch anything (except the front and back covers, looks like).
All I can think of is maybe it's a spacer to keep the body from denting in the middle. Anyway, mine's in and all is good. Thanks Old Turkey!
댓글 달기
Have you foumd where this goes - same problem?
해당 답변은 도움이 되었습니까?
점수 0
댓글 1개:
is it a pin for the strap to be tied to?
댓글 달기
it looks like the axel rod with spring of the battery door. i have this camera to repair the ccd sensor. everything its working but i can´t get images comming through the lens thanks for the ifixit site
해당 답변은 도움이 되었습니까?
점수 0
댓글 달기
I have a Sony DSC-T1 Cyber-shot - Digital Camera - 5.1 MegaPixel - DSC-T1. I haven't used it in a year. I just connected the cable charger to get it to work. ASll I'm getting is a window with the clock set options. I've reset the camera. However, I'm unable to use all other functions. Do you think I need a new battery?
해당 답변은 도움이 되었습니까?
점수 0
댓글 달기
귀하의 답변을 추가하세요
Sean Mann 님은 대단히 고마워 할 것입니다.
조회 통계:
24 시간 전: 0
7일 전: 5
30일 전: 6
전체 시간: 1,778
