주요 콘텐츠로 건너뛰기
2014년 9월 19일에 출시된 이 4.7” 스크린 iPhone은 iPhone 6 Plus의 작은 버전입니다. 모델 번호 A1549, A1586 및 A1589로 식별됩니다.
4994 질문 전체 보기
Pictures taking WITH flash are dark/black
Hello everybody hope somebody can help me out! ;-)
I have repared an iPhone 6 model A1586, everything is working fine as expected, except when taking pictures with flash, then they get really dark or almost Black if it is a closeup of something :/
has anybody had that issue before with an IPhone? The camera is working fine when taking pictures without flash, or using flash while filming - no problem there. Its only when taking pictures.
hope somebody out there can help me! :)
답변되었습니다! 답변 보기 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 1
댓글 달기
답변 1개
선택된 답변
It’s almost as if the flash wan’t properly synchronized with the shutter. However, this doesn’t sound like a hardware issue, you should try doing a reset of your device by holding the power and home button for ~10 seconds.
If that doesn’t work, then you could try replacing the camera to see if that helps, they aren’t that expensive.
해당 답변은 도움이 되었습니까?
점수 2
댓글 달기
귀하의 답변을 추가하세요
emilrasmussen1502 님은 대단히 고마워 할 것입니다.
조회 통계:
24 시간 전: 1
7일 전: 4
30일 전: 15
전체 시간: 1,769
