주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
2016년 9월 16일 출시. Model A1661, A1784, 또는 A1785. 32, 128 또는 256 GB 환경 설정 / 로즈 골드, 금색, 은색, 검정색, 칠흑색 및 (Product)빨간색으로 제공됩니다.
iPhone 7 Plus Black Screen
My phone has just a black screen but my phone is still on and calls and everything is coming through. Before all of this happened though I had low battery, I’ve tried everything but nothing has worked. Will letting the phone charge for a while and then try hard resetting it work?
답변되었습니다! 답변 보기 저도 같은 문제가 있습니다
좋은 질문입니까?
점수 0
댓글 1개
Or taking it, letting it charge, and then do a restore on it?
댓글 달기
답변 1개
선택된 해법
Have you opened up the device to replace the battery?
Disconnecting and re-connecting the screen while the battery is connected can cause the backlight circuit to blow. To confirm if this is the case, connect your phone to an iTunes enabled computer and then shine a bright light on the screen. If you can see a dim image, the the backlight is not working. It could either be the screen or the circuit on the logic board.
이 답변이 도움이 되었나요?
점수 2
댓글 달기
답변을 추가하세요
Bradley Campbell 영원히 감사할 것입니다.
조회 통계:
지난 24시간: 1
지난 7일: 1
지난 30일: 17
전체 시간: 552
