주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
7.9 inch display / Model A1432 / Available in black or white / Announced October 23rd, 2012 / 16, 32, or 64 GB capacity
FPC connector socket replacement
Is the FPC connector socket interchangeable with a different model?
답변되었습니다! 답변 보기 저도 같은 문제가 있습니다
좋은 질문입니까?
점수 0
댓글 달기
답변 1개
선택된 해법
Which FPC connector are you referring to?
I’ll assume you are referring to the digitizer FPC as that is the one that fails the most. Apple does a great job in using different connectors almost all of the time ;>). They use different types and genders on virtually every generation of device, with only a few exceptions. The mini digitizer FPC is used on the mini, mini 2 and mini 3 but no other FPC used through out their product lineup is the same. You can find it here.
Replace the digitizer cable connector on the logic board of an iPad mini. This part requires microsoldering. 이미지
제품
iPad mini Digitizer FPC Connector J1700
$2.99
이 답변이 도움이 되었나요?
점수 1
댓글 달기
답변을 추가하세요
dreaminbeech 영원히 감사할 것입니다.
조회 통계:
지난 24시간: 0
지난 7일: 1
지난 30일: 1
전체 시간: 77
