주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
W123 섀시는 1977년부터 1985년까지 생산된 Mercedes-Benz의 쿠페, 세단 및 왜건 모델인 240D, 300D, 300TD, 280E 등을 포함합니다.
Headlights and fogs not woking
1985 Mercedes 300 cd turbo
head and fog lights do not turn on
have replaced all fuses, checked ground on passenger headlight corner
passing light lever on turn signal will make headlights work therefor its not the bulbs
rear defrost out
cruise control out
tachometer works, speedometer works, turn signals work , rear lights work, hazard lights work.
no loose wires apparent
help please
답변되었습니다! 답변 보기 저도 같은 문제가 있습니다
좋은 질문입니까?
점수 0
댓글 2개
I went to my fuse panel last night and checked for continuity which was present, will check the voltages tonight. I did however put a brand new light switch in a few days ago and got nothing so am assuming I do not have a bad switch unless a terminal was connected improperly by someone diddling with it prior to my work on it
의
it was a loose connection under the fuse panel and to the left of the brake pedal beneath the kick panel drivers side
의
댓글 달기
답변 3개
선택된 해법
Have you read and completed this guide to w123 fuses and fuse box service ?
Mercedes W123 퓨즈 점검 방법
이 답변이 도움이 되었나요?
점수 0
댓글 4개:
First thing I did was remove all the old fuses followed by light sanding of all contacts and use of contact cleaner. All new fuses wer then added.
Also check and cleaned the ground
의
So did this fix it?
I just checked my low beam circuit and the rear tab of the low beam fuses go hot (12+) when you turn the headlight switch on with dip set on low beam. If you don’t get that result one of the two switches is probably bad leading to this open circuit. Mine is a 1985 300 SD (USA) by the way.
의
went to the schematic and found there was a connector between the switch and the fuse box. It was loose and with some effort mushing them together the lights came on. In the process I lost my parking marker lights.
On the switch there are 4 leads coming off the terminal to the left of the two red power leads. Up at the fuse box there is only one. So you go from 4 to 1. the lead got snipped and place on a fresh lead to the switch terminal and all is operational.
It required undoing the small nut that holds the fuse panel in place and getting at the harness below it.
의
Can you show my that schematic to find that connector my fog lights do not work
의
댓글 달기
1983 300td had same problems replaced bulbs I cut the stupid German connectors and spliced the wires together only high beam and running amber lights work fuse is testing good by test light I figured ground was good but I said what the hell took it off and passenger high beam dimmed so I know ground was good not for sure what to do it’s either what this post is saying and if so f that connector it will be American spliced together and wrapped with electrical tape or it’s headlight switch or lever
이 답변이 도움이 되었나요?
점수 0
댓글 달기
It was the lever
이 답변이 도움이 되었나요?
점수 0
댓글 달기
답변을 추가하세요
zenon duda 영원히 감사할 것입니다.
조회 통계:
지난 24시간: 1
지난 7일: 5
지난 30일: 28
전체 시간: 2,904
