주요 콘텐츠로 건너뛰기
A series of 40 inch LCD HDTVs by Sony.
20 질문 전체 보기
no picture, has sound, no t-con
I have a sony bravia kdl-40w605b.
There is no picture but the sound works fine at least I can hear the beeps from the menu even though I cannot see it.
The backlight is working fine.
This would normally be put down to a t-con failure however there appears to be no dedicated t-con board. The t-con cable goes directly from the mainboard to the screen.
I have replaced both the mainboard and t-con cable with no joy.
Is there something I am missing? Could this be the power board or something else?
Update.
So new power board caused 6 red blinks so I'm guessing that I either got sold a duff board or it's the wrong board despite having the same model number.
Im including a picture of the boards now.
Update (09/08/2018)
So I figured it out. I feel like an idiot
답변되었습니다! 답변 보기 저도 같은 문제가 있습니다
좋은 질문입니까?
점수 3
댓글 7개
Hello there i have same problem on KDL42W706B , replaced tcon but still same , all voltages looks fine but there is no any image or osd , Backlight working well , i have sound , i can see backlights lighting led panel well , but nothing appear in screen. i didnt found anything strange at the parts. Did you fix your tv ?
This is most common issue for Sony but there is no any information about solution.
So, what was the solution of the problem? Thanks!
Can you answer what was the solution?
I‘m scrolling up and down and again ...
I can‘t find what the solution was in the end. Can you please tell us, what you did to fix it? I have the same problem! Thank you.
Hi! I have the same problem. Everything works ok but I don’t have image. The backlight is working, the sound and the reaction of the TV when I am changing channels but I don’t have any image. I have replaced the LD-HM board but the problem still remains. How did you fixed the problem?
댓글 2개 더보기
댓글 달기
답변 4개
선택된 해법
@thelazydj I would have measured the output from the power supply to the mainboard first. Remember that it is your main board that turns on the power supply etc. since you already replaced the main board and the cable, you only have the power supply left. Here is the Sony triage sheet for your TV model
It shows which boards are common failure based on your TV’s symptoms. You said you replaced the main board but did not tell us if your replacement included the tuner board. Sony part number A-1998-231-A. Post some images of the boards you replaced. Use this guide for that 기존 질문에 이미지 추가하기
이 답변이 도움이 되었나요?
점수 2
댓글 6개:
Thanks for the reply.
I have updated and included a picture of the boards.
If the board attatched to the mainboard is the tuner board then I have not replaced that one yet.
I have sound fine through all sources, backlight is fine. Mainboard and t-con cable are fine. Power board is inconclusive (read update). So really just the tuner board to check as there is no t-con board in this set.
Admittedly I am somewhat an amateur an this is only my 4th fix but I am completley stumped. I'm starting to think the panel may be dead as nothing else appears to be working.
@thelazydj usre the panel is always a possibility but your TV's symptoms would be atypical for that. "If the board attatched to the mainboard is the tuner board " yes it is. That is definitely a board that can cause your TV's issues.
Just read about the 6 blinks and as you can see on the Sony triage this could be a mainboard issue or a panel issue. Double check the board and do not rule out the tuner board yet. It is directly connected to the main board and could cause teh main board to either fail or just not getting signal etc.
The board on the left hand side of the picture is called the LD HM board and may be the problem board here. It is part number: A-2194-269-A. I would try that one.
Dan
@abrsvc you are absolutely right. If you read the answer you would have seen that it is a Sony triage. I am sure that in your vast experiences you have come across the Sony triage flow charts. In my comment I erroneosuly referred to it as a Samsung, but at least I know to correct my mistakes!
Thanks for the replies all.
I have a new av board on the way (very cheap thankfully) so I'm hoping that is it. Or it could be strip and sell time for the parts I know work.
The 6 blinks only occured with the new power board once i put the old one back in there were no blinks so it could still be that as I think I got a duff replacement. Will update when the av board arrives
댓글 1개 더보기
댓글 달기
Most likely is the PSU. check visibly for leaking or bulging capacitor tops also if an ESR meter is available check for the series resistance of each capacitor . The PCB may have one or more dry joints…use a magnifier to check the board.
이 답변이 도움이 되었나요?
점수 1
댓글 1개:
I was thinking psu, I have ordered a new one just waiting for it to arrive. Merely curious incase it could be anything else. Thanks
댓글 달기
Check the connections on both ends of the T-con cable. This is a flat ribbon cable that goes to the panel. It is possible that the cable itself is defective. Also, verify that there is no picture on the screen using a flashlight.
How do you know that the back light is working properly?
Update this with the results of the above.
Dan
이 답변이 도움이 되었나요?
점수 1
댓글 1개:
As I stated I have replaced the t-con cable and mainboard with no joy. Flashlight test revealed nothing hence no picture and the backlight just IS working quite plainly. The screen lights up when powered up just no picture.
If not the psu then I'm thinking the panel may be done for, unless there is anything else I'm missing?
Thanks
댓글 달기
Tcon board
Also upon replacing boards you may get green and Amber flashing light which means it needs a update
이 답변이 도움이 되었나요?
점수 1
댓글 1개:
Update via downloading firmware from Sony website ( Sony model xxxxxx) into search engine then follow their instructions also a usb is required
댓글 달기
답변을 추가하세요
simon elliott 영원히 감사할 것입니다.
조회 통계:
지난 24시간: 0
지난 7일: 6
지난 30일: 23
전체 시간: 21,942
