주요 콘텐츠로 건너뛰기
A portable, rechargeable jumpstarter that can provide instant jumpstarts for cars and trucks.
24 질문 전체 보기
Road master power station
I have a roadmaster power station it is been in my trunk dry and not exposed to the weather and went to go use it and the battery is dead I tried to plug it into the AC outlet and it does not charge what can I do
이 질문에 답하기 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 0
댓글 달기
답변 1개
Try plugging it in and leaving it for a night, then, try using a different power cord, if it takes AC directly.
Sometimes you have to sort of “push and pull” the cells to get them to start taking a charge again.
sealed lead-acid batteries are practically bullet proof.
but if nothing works, gotta crack it open, and change the cell - find a electronics parts store’ - they will give you a reasonable price for the battery - Also remember you can sometimes join 2 batteries together to make the final voltage you need, if you want to Frankenstein it. like if it needs 12v - and you can only find two-6v cells, as long as the amperage is the same or more then they can be joined using a pigtail, i did this for mine a while ago. BUT you would need to read up on doing that properly to not cause a meltdown.
errrrr, you can check the fuse with a meter :)
해당 답변은 도움이 되었습니까?
점수 0
댓글 달기
귀하의 답변을 추가하세요
Howard mcfadzen 님은 대단히 고마워 할 것입니다.
조회 통계:
24 시간 전: 2
7일 전: 4
30일 전: 7
전체 시간: 99
