주요 콘텐츠로 건너뛰기
모델 A1311 / Mid 2011 / 2.5 & 2.7 GHz Core i5 또는 2.8 GHz Core i7 프로세서
432 질문 전체 보기
Mac Data Recovey software Bootable
Any data bootable data recovery software for backup in case of OS corruption (like Hiren’s BootCD on Windows).
Is there are any software on Mac environment software like disk drill , paragon on Mac based still not tested that can be used to test different Apple MacBook or iMac with out installing on each machines.
답변되었습니다! 답변 보기 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 0
댓글 달기
답변 1개
선택된 답변
Apple does a good job here you have on the newer systems the hidden recovery partition on the systems drive. Even if you loose the drive you have the internet recovery option all built-in! To save time you can also create bootable OS installer drives (I’ve got about ten now). These are nothing more than a USB thumb drive already setup (see below).
As for your personal data and your apps you have built-in TimeMachine! This app allows you to setup a external drive as your backup drive to automagically back up (if you set it up to do this). If you have multiple systems you can even setup a system as your TimeMachine server so the drives on it are used at the backup server. I have a Mac Mini setup as my media server and is my backup server as well. That way my three systems are backed up.
Beyond that gets into tools used to fix drive issues like Drive Genius and antivirus and malware apps.
해당 답변은 도움이 되었습니까?
점수 1
댓글 달기
귀하의 답변을 추가하세요
Rajeev 님은 대단히 고마워 할 것입니다.
조회 통계:
24 시간 전: 1
7일 전: 1
30일 전: 3
전체 시간: 71
