주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
이 완벽한 홈 시어터 시스템에는 다중 각도 및 줌 기능이 있는 프로그레시브 스캔 5디스크 DVD 체인저, 720와트 앰프, 그리고 돌비 디지털/DTS/돌비 프로 로직 II가 내장된 슬림한 디자인의 실버 DVD 리시버가 포함되어 있습니다. 또한 5개의 동일한 실버 풀레인지 위성 스피커와 120와트 서브우퍼도 함께 제공됩니다.
won't stay powered on
this system has been in storage for 12 years. i powered it up today. the red stand by light comes on, indicating system not on. when i press any of the disc or am/fm buttons, the display lights up indicating system on, but the goes back to system off mode in a few seconds. something i’m missing?
이 질문에 답하기 저도 같은 문제가 있습니다
좋은 질문입니까?
점수 1
댓글 3개
@sarah_rver is your system a JVC TH-M303?
의
yes it is. had it for 13 years
의
@sarah_rver just to clarify, it turns on but after a few minutes it turns off. Any LED lights on or any sign of life when it turns off?
의
댓글 달기
답변 1개
가장 유용한 답변
Neither the user nor service manuals provide any particular clues based upon what you have described. Therefore, I must start with the typical failure. Disconnect the speakers and try again. I expect that the unit will power up normally.
You can reference the service manual here: http://www.go-gddq.com/upload/2010-02/10...
The main power amp resides inside the subwoofer. Check to see if there is a protect light on the subwoofer.
If there is a light or the unit only “works” with the subwoofer disconnected, I would suspect that one of the amp chips inside the subwoofer is defective and further investigation is required. There are 2 large black amp-packs inside the subwoofer (STK413-400 and STK413-=430). One or both of these may be defective.
Try removing the speaker connections and report the results here.
Dan
이 답변이 도움이 되었나요?
점수 2
댓글 달기
답변을 추가하세요
Sarah Hughes 영원히 감사할 것입니다.
조회 통계:
지난 24시간: 0
지난 7일: 2
지난 30일: 14
전체 시간: 1,319
