주요 콘텐츠로 건너뛰기
Apple iPhone 5s는 2013년 9월 10일에 발표되었습니다. 수리는 이전 모델과 유사하며 스크류 드라이버 및 비집는 도구가 필요합니다. GSM 또는 CDMA / 16, 32, 또는 64GB / 은색, 금색 및 스페이스 그레이.
3530 질문 전체 보기
There is a slight yellow tint on my iPhone 5S screen replacement
Hello, recently my friend gave me his old iPhone 5S to fix as it was old, but still worth salvaging. It needed a new screen and battery. Long story short, the battery went perfectly, but the screen is having issues. Everything works well on it. Touch ID, touch itself, front camera, ear speaker, etc. But, when the screen is installed/placed into the body of the phone, a slight yellow tint appears at the top. It is barely noticeable in the picture, but is clearer in person. I know it is not the screen because upon taking the screen out of the phones body, it disappears. I was told it was a pinch point within the screen caused by imperfect installment of the ear speaker, camera, etc., but even after uninstalling everything and reinstalling it multiple times, the issue still shows up. I keep watching YouTube videos and looking at tutorials on different websites on how to replace it and nothing I do seems to be wrong. Anyone know any errors I could be making? Or how to fix it?
Thank You!
-Caleb
답변되었습니다! 답변 보기 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 0
댓글 2개
Thank you guys for the responses! There was a slight lift! The battery connector was not folded to fit in the gap between the logic board and battery, and was actually protruding upwards. I do not know how it created a yellow tint at the top of the phone, but it worked after folding it like the original battery…
Thank You!
I have "EXACTLY" the same issue! but my battery connector is fine :/
댓글 달기
답변 2개
선택된 답변
It’s a lift—-you have to find it. There is always a reason. If you do enough 5s screen changes you will find that you never get a lift, then when you do it jumps out at you immediately—-something is wrong! Usually it will be something pretty minor, a shard of glass, a bracket turned around upside down…the new battery having a label on it that makes it too thick where the old one didn’t….there is definitely a reason and you have to just figure it out.
I’d start by eliminating the variable of the new battery. Take it out and see if your lift goes away if you put the old battery back in with no adhesive.
해당 답변은 도움이 되었습니까?
점수 1
댓글 1개:
hello i have a simaler issue as well gold iphone 5s tmobile i have a used screen and i havent tried replacing it but ive noticed it dosent really matter because with the screen out fully i get a yellow tint as well it matches the gold nicely but then after a few minutes of the phone being on it has small seizures they are very clearly seen the phone thinks im touching the screen and reacts and it wont stop once it starts im hoping this isnt a motherboard issue or internally because the gold home button still works and i have to use this phone like this recently i bought a battery from ifix it just came in the mail today! im excited as the battery is new and fresh as the old one and screen needed replacing but i dont think my issue is the battery pull tabs they are very small and would hardly make a difference but i hope you can help me none the less it dosent help ifixit dosent have a white screen to match the origanal but ill go look anyways thanks for your help i did notice the screen is flush with the phone so i dont know what would cause the issue i know its not the battery cause its new as of today
댓글 달기
가장 유용한 답변
Yellow mark indicates uneven pressure from behind screen pushing on that spot.
Try loosening the side screws a bit for the back metal plate on the screen and see if that helps.
Are the corners of the iPhone housing frame dented inwards in some way?
That can cause that issue too as it would mean the screen is not sitting flush with the frame.
해당 답변은 도움이 되었습니까?
점수 5
댓글 1개:
Thank you for the reply! The screw loosening did nothing and the screen is flush with the phone. The corners were bent in, but using a homemade fix, I was able to bend them out and the screen goes in fine. I do not know what the issue is at this point.
댓글 달기
귀하의 답변을 추가하세요
SectorGaming 님은 대단히 고마워 할 것입니다.
조회 통계:
24 시간 전: 1
7일 전: 4
30일 전: 11
전체 시간: 9,751
