주요 콘텐츠로 건너뛰기
Samsung Galaxy S4 모델 i9505는 13-megapixel 후면 카메라 및 5-inch 1080p 화면이 특징입니다.
526 질문 전체 보기
When I turn my phone on it turns itself off again
My phone is a samsung galaxy s4. For a while my phone has been dying way before it gets to zero. sometimes as high as 70 then i will plug it in and it says it is at 0.
so finally i decided to get a new battery figuring it was a battery problem. i don’t actually have the battery yet, i just ordered it today and it should be here by the 10th. but just today the phone turned itself off and i assumed it just died but when i plugged it in it said it was at 40 but it usually shows 0 after i plug it in.
later it turned off again. and then later, again. i tried turning it on and it turned itself off right away. every time i try to turn it on it turns off when it gets to the lock screen or sometime before that on the version screen. its fully charged.
does this still have something to do with the battery or is there another problem?
is it fixable or should i just get a new phone?
이 질문에 답하기 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 0
댓글 1개:
Hi @retrofangirl ,
Does it do this if you leave the charger connected and switched on? (from your question I'm not quite sure if it does or not)
If it doesn't do this with the charger connected, it suggests that it is a battery problem.
댓글 달기
답변 1개
Try reflashing your stock rom through odin.
해당 답변은 도움이 되었습니까?
점수 0
댓글 달기
귀하의 답변을 추가하세요
Charla Painter 님은 대단히 고마워 할 것입니다.
조회 통계:
24 시간 전: 0
7일 전: 2
30일 전: 2
전체 시간: 38
