주요 콘텐츠로 건너뛰기
2017년 11월 4일 출시. A1865, A1901. GSM 또는 CDMA / 64 또는 256 GB / 은색 또는 스페이스 그레이. ("iPhone 10"으로 발음합니다.)
1097 질문 전체 보기
There’s a black “ink”spot in the bottom right corner of my screen?
My screen has no cracks on it, I’ve dropped it twice.
The first time it landed backside down and I noticed that a small black spot that sort of resembles ink appeared. I dropped it again today, it landed the same way, and the spot got bigger.
I can still control my screen directly on where the black spot is im just not sure what it is or how it could be repaired
답변되었습니다! 답변 보기 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 9
댓글 달기
답변 3개
선택된 해법
If you could post a picture, we could say for certain but it sounds to me like the actual OLED has been damaged. If that’s the case, then you will need to replace the screen.
If you want a high quality screen replacement, then Apple is still your best bet. However if your housing is damaged, they may refuse to replace the screen, in which case an independent repair shop will be able to replace the screen. Just ask about the quality level of the replacement screen because there are some inexpensive (relatively speaking) aftermarket LCD’s and now aftermarket and premium level OLED.
해당 답변은 도움이 되었습니까?
점수 9
9 Comments:
Hey does it spread all over after you dropped off ??
It's not spread ed it's just down at the last of the month
I just wanted to know what the plus was for at the end of the calendar
Nothing appears to be damaged it's just got a plus sign at the end of the calendar.
I don't believe anything is damaged if it is then the glass and back are a waste of mone
4에 댓글 더 나타내기
댓글 달기
Black splotches inside LCD display are caused by dropping the phone.
To get that fixed you would need to get the hole display replaced. Most expensive phone to get it replaced.
[연계 제품이 누락 또는 비활성화 됨: IF377-003-1]
해당 답변은 도움이 되었습니까?
점수 6
4 Comments:
Does the warranty cover this type of damage?
Does it grow with time on iphoneX?
It can get worse over time as it bleeds like ink in a display that expands. This would not be covered under normal warranty as it is considered physical damage.
Is there a way to arrest it?
댓글 달기
So I cracked my phone at the bottom right corner of my screen and it is showing vertical lines on that side of the phone can I get it fixed?
해당 답변은 도움이 되었습니까?
점수 0
댓글 1개:
You'll need to replace the display.
댓글 달기
귀하의 답변을 추가하세요
Xandria 님은 대단히 고마워 할 것입니다.
조회 통계:
24 시간 전: 38
7일 전: 252
30일 전: 1,133
전체 시간: 197,459
